I am trying to use the angle cylinder on the quick hitch and found the spool in the hydraulic valve is stuck. Will using a punch and hammer to tap on the spool to try to free it cause any internal damage to the hydraulic valve? Could there be pressure in the valve keeping the spool from sliding? I have tried it both with hoses attached and unattached and have been unable to move the spool? Can this be fixed or will the entire valve need to be replaced?
