Was repairing a 9n that had set up for a year and had a stuck clutch. I tried the suggestion I found on here from NashRanch and it worked. Just thought someone might want to know if it happens to them.
" Re: clutch problems
The clutch on my 2N sticks also...can't put it in gear with it running. What i do is turn it off and put it in 3rd gear and rock the tractor back and forth. Make sure the clutch pedal is blocked open. It will eventually break loose "
