Ok, this is my first attempt at stripping the grass today using my lawn roller.
I filled it half way with water, I think it looks pretty nice.
It is a [email protected] in tight turns with the roller in back which takes extra time.
Ok for open areas, but I don't think I'll do it every week.
What'a think fellows??? :dunno:
BTW........Did I tell you how much I like my X720.......:sidelaugh
Mike,
If you like the looks of a striped lawn and want to do it at the same time as you mow, then you may want to consider getting a BM23648 striping kit for you mower.
The X700 roller striping kit attaches easily to the 54-in. and 62-in. Edge™ Xtra Decks and the 60-in. 7-Iron™ Mower Deck used on Select Series™ X700 Ultimate Tractors.
The roller bends the grass over, creating the premium 'ballpark' after-cut striping effect, greatly enhancing the finished look of the turf. The 2-in. (51-mm) diameter rollers are mounted to a strong 7/8-in. (22-mm) steel shaft.
Key features:
Allows mowing and rolling the lawn at the same time
Installs quickly and easily, replacing the rear anti-scalp wheels
Adjusts to varying cutting-height settings without tools using existing anti-scalp wheel hardware
Does not affect the ability of the tractor to climb over curbs
Simple to service and maintain
Roger
Mike,
Key features:
Roger
Thanks Roger but for $265.00 suddenly it's not that important.
Besides I can just use my lawn roller and that's paid for.
