Hi all...
I have a Craftsman YT4000 that I love. I use it not just for mowing, but for a lot of utility around the yard.
There is one very frustrating thing about it though, I could never get it to cut evenly. The deck has two blades. I would expect that if they were not level, the outer part of one of the blades would cut closer to the ground, but in my case the inner part is getting the close shave.
Here is a photo of what I mean:
Uneven Cut Photo
If you look at last cut row on the left, I was coming in the direction of the camera. It appears that the blade on the port side of the tractor (right) is somehow cutting lower on the inner side. I marked this with #1. This is especially bad on turns. If you look at #2, I am going in the opposite direction, away from the camera, so it is cut lower on the left.
I tried to measure the distance from the blade to the ground as suggested in the manual. I tried adjusting the deck up and down with the adjuster on the port side. I can't get rid of this.
Any suggestions?
Uneven Cut Photo
Any suggestions?
