1 - 8 of 8 Posts
The original engine was replaced with Briggs & Stratton Vanguard model# 303447 type 1249-A1 4385 code 96100111. So far my list of parts is:
Rod–Hand Choke​
692075
5.45​
choke clip​
691723
4.65​
air breather tube​
806083S
10.85​
oil filter​
491056
7.85​
Air cleaner kit​
5050K
16.80​
throttle handle​
20.00​
starter​
499521
46.03​
There is a starter solenoid clamped to starter, but the what is this?
2474586
After feeding off battery, red wire goes to:
2474592
and that's the end of the white wire. I'm not an ignition expert but i'll be needing to see wiring diagrams for the engine and see what i have to make it work...
That big hose clamp attaches the solenoid that goes around the starter...looks like an additional solenoid was attached next to the battery...I bought the ball valve, vinyl water tube, tees and pvc pipe...I need to know how drums get the water sprayed on them...itsa gravity fed system from bottom of water tank...
Relay at the battery and starter solenoid at the starter unless the starter uses a mechanical direct drive.
Sprayer must use a wick system then. I see no mention of a pump for spray tips.
The PVC pipe is all that is shown, so there must be holes to allow water to flow out onto the drums...but I need to know how many and what size...gravity fed water system...
The owner manual shows the tube parts number and what lengths to cut them to. Do not even show what position the hole need to be in when installing the tubes. If not to ridicule's in price you may have to buy one to find out if tech will not tell you. Wish I was of more help. I would ask these people.
TECHNICAL ASSISTANCE 800-478-1244 FAX: 310- 631-5032
1 - 8 of 8 Posts
