1 - 20 of 29 Posts
Run ahead of the pack
After I install the K66Y on my X300 at the beginning of the year, I did not have the opportunity to really test the capacity of the transaxle.
Now it's done and I will not be afraid of doing big task. :D
Check the video Here, enjoy. :)
Former MTF Admin.
Re: Stladrill X300"GT" K66Y pulling test
:congrats: Congrats ! real nice job, and looks like you should have no problem with plenty of tranny power :fing32:.
Very cool tractor you have there! Nice upgrade for sure. The K66 is tough. FYI, there are no relief valves in that transmission (or any Tuff Torq transmission), so be careful fully loading it like that where the wheels can't spin. Wheel spin is "relief".
Enjoy! Please share some vids of you working it!
I was expecting the concrete to bust loose with all that pull!!!!
Yes I know about the relief, that's why I did not push it at max only haft and I did not put the rear suitcase weight to give it a weak point. :fing32:
Nice, i was waiting on the concrete to give! Great job!
Likes Vintage JDs
Stladrill,
Nice job on the pull test. Very impressive. You must have the toughest X300 going!
I really like your tractor. I bet you can't wait for l'hiver! Which should arrive in a couple weeks, right?:D
Engine Tech -- Good comment there. But one quibble: My understanding is that the TT K92 does have a built-in relief valve. No? If you have some expertise on this, maybe you could come over to this thread and comment? Thanks.
Discussion Starter · #10 ·
Stladrill,
:thanku: :snowing::sidelaugh
Stladrill you wrote the book on this subject !! Good Job man !
Discussion Starter · #15 ·
Thanks, folks!
Note: It’s very kind of you all for the French comment, it's appreciated.:fing32:
Citizen of Earth
:thThumbsU You asked me to enjoy the video and I did enjoy it. I also expected to see the concrete break away. Looks like you have your machine now set up for any task you need done.:thThumbsU
Some of the heavy duty TT trannies do have a relief valve. Case in point, K92 in my 2305 has a press. relief valve in the hydro drive circuit...
cheers!
What is gained by changing the trans from the stock X300 to this one? My X300 pulls just fine unlike my old 175 Hydro that wouldn't go up steep hills.
Discussion Starter · #19 · (Edited)
The short answer is: the X300 is equipped with a Tuff Torq K46.
You will find many thread/post about that subject. :fing32:
cheers!
You are right, I made too broad a statement as I was thinking only lawn tractor and L&G tractor trannys. Compact utility tractors have always them like you said. Thanks for the correction!
1 - 20 of 29 Posts
