My '56' UTS Special has been sitting since early spring this year. While checking things over I found water in the distributor and a sticky exhaust valve on the #1 cylinder. It appears that some water got in through the rocker cover retaining studs. Looks like I need to seal those up when I put it back together. The valve loosened up pretty easily by spraying some penetrating lube on the valve and tapping on the rocker lightly with a rubber mallet. I have the distributor torn down and will clean, bead blast, and lube all the parts before assembly.
152.7 KB
90 KB
120.1 KB
