I knew about the neutral trick. I used it many times before I rebuilt the motor unfortunately. :crybaby:
As for the deck, it is a bit of a PITA and since it spent practically a decade in a scrap pile needed a ton of TLC to get back up and running. I still need to adjust the blade heights as they have a set screw on each shaft for height adjustment and well it is a lot of work tearing it apart setting, re assembling and trying just to find one blade is slightly off. My deck is in bad shape so I mostly only use it to cut where I am not trying to make it look nice and is more a rough "ditch" mower for me. It is on the todo list to get the deck back into "new" condition. But I have two other mowers that do a fine job. a 08 JD LA145 and a Gilson both with very large decks so having a 3rd would just be greedy.:1287:
The hubs on this unit are a 1 piece so that must be where the confusion is.
I am very curious to see this loader, I think I saw a picture of one on a much newer 430. The bucket I made that you see in the picture is a design I saw on a much newer Steiner that I copied and it works amazing but I could improve on the design.
As for the tiller I do have mine kicking towards the Steiner. I did it this way because as you described I did not want tire tracks. My tiller weighs maybe 80~100#. Cant be much because I man handle it to get it attached to the Steiner very easily. But like I said before it used to be a self propelled unit with a 5hp, very quickly I learned that 20hp was way to much and was breaking shafts on the tiller. I found if I ran the motor at 1/2 throttle RPM less than 2.4k it worked fine and nothing broke so that is what I do.
I am a little concerned about the motor as when rebuilding I got the factory briggs rebuild book and it specified that two dippers are required for loaded operation under WOT. Mine only had 1 dipper and that is how I rebuilt it. Tempted to add the 2nd dipper but it ran 3k hours on 1 dipper and IMHO with the hydraulics this thing was loaded often in part throttle. Any thoughts on that?
