Have an JD LA115 bought in 2010 and it failed to start. It started when a bee decided to put mud in the key ignition hole. Had to replace the ignition which is easy and only plugs in one way. After that It was hard to start but could by turning the key to just the right spot. Thought the switch was bad so bought another. Same problem but but it would start. FInally had JD come get it for their maintenance program and told them about the starting problem. First call from them said they needed to adjust the valves for the starting problem. $50 Next call was that didn't work, and it was the Camshaft issue $700. OK, I'm not mechanically inclined, to replace engine parts but know someone who is but not locally. SHould I try from a trade-in deal or have them fix it?
Hope to get some ideas/suggestions by Monday when I have to tell JD maintenance what my plans are
Thanks
Thanks
