1 - 10 of 10 Posts
I have a 12.5 HP Vangaurd twin. 2999277-0108-01 engine that I replaced the starter on today. Engine cranks but will only start with starter fluid.
sat for about a year. I put new gas in it and drained the carb fuel bowl and lines to the carb.
Will only run if I spray starting fluid in the carb! How do I get it to run?
Thanks
Maybe the jet in the carb is clogged from sitting so long. A small stiff wire will work nicely.
Okay so on the top of the carb stick a small stiff wire down the tube with the jet or remove the jet, stick wire through it, and put it back?
Jersey Mechanic
You need to remove the fuel bowl and float and clean the mains, use a small piece of wire to clean the passages. Make sure fuel flows into the bowl prior to putting it back together.
Dan
Dan
Can you explain what mains are? I am looking at a diagram of my carb and I can see what the float and bowl. Thanks
Nevermind! You guys ROCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Its running! Thank you Thank you Thank you!!!!!!!!! You were both right, carb was gummed up. I took off the bowl and blew out all the openings with compressed air! Sweet!!
I love it when a suggestion works out. Congrats!
1 - 10 of 10 Posts
