1 - 14 of 14 Posts
Well, after straightening out my battery issues, a few days later my plastic starter pinion gear stripped out. Starter itself seems fine. Can I swap in a new pinion or am I looking at a new starter? Looks like the pinion slowly wore away from the top down over time until there wasn't enough gear left to contact the flywheel teeth.
Also, I can't seem to find the parts on the toro and other parts websites......
Thanks!
1985 WH 211-5, 11 hp Briggs
The voice of reason !
That is so weird my fiancée and I just stopped it at Tractor Supply Co. today and I was debating whether or not I should just get a pinion gear to be on the safe side.
I think RR is right their about $8.00 and they had 5 on the peg, should be easy to find.
Thanks!
Check out this page
http://tewarehouse.com/Catalog/0515?range=41,56,56
from South Jersey
The starter gear is an engine part so you need to look under Briggs & Stratton, not Toro or Wheel Horse. You'll need all the numbers off your engine to make sure you get the right one unless one size fits all. I don't own a Briggs engine so I'm not too sure.
If I'm not mistaken Briggs only has one plastic starter pinion for most of their electric start engines ?
I think they are all the same to. I can get them for about $3.
Kyle
Where did you see them that cheap ?
The local auto parts store has them. Also I was at a Flea market bought a hand full they were 2 for $5. So I am set for a while lol.
Kyle
1 - 14 of 14 Posts
