I believe the switch is the culprit here. I recall it was sticky, I shot it full of WD40 and switched the key back and forth a bunch of times trying to loosen it up. Maybe I left it in the start position.Better question, all my Sears tractors have a spring loaded switch that turns the switch out of start position as soon as you let go of the key. So even if your grandson was messing with it, it should not be in start position without a hand on the key.
Yes, I could see the key being left in the on position killing the battery, but not in the start position.
Mark, I think those guys only do NYC.
