1 - 8 of 8 Posts
Tractor addict
My 1970 SS12 is driving me up a wall, I have been tinkering with the carb trying to bring down rpm during idle. It idles in what I think is about medium throttle for an SS12 with an HH120 Tecumseh but there is no change when I adjust the idle or high speed screws. I can adjust the screws off what the manual says to start at but there's no change back and forth 1 turn so I think the settings provided by the manual are correct for this motor but it idles way to fast. This fast idle I think is creating a massive vibration that numbs my feet after driving for a couple minutes. I don't think the mounting bolts are loose because the engine does not shake around at a different shake than the frame.
Any ideas? I really don't want to play with the governor because the last time I touched a governor lever bad things happened.
Thanks!:thanku:
Have you cleaned the carb?99% of the time when i have a tractor that's untunable it needs a carb rebuild :fing32:
or an intake leak
Cranky Motorsports
or if the screws from the butterfly screws fell off in the motor.
Finally at 1k!
Do you have the idle screw, the one that MOVES the throttle, adjusted so it runs at half throttle?
Tractor addict
Discussion Starter #8
that was the problem, how I missed it I don't know. I must have part-timers.
thanks for the help!!!
:thanku::thanku::thanku::thanku:
1 - 8 of 8 Posts
