To test the ignition you unhook the kill wire. There should be a little screw with two wire's hooked to it, on the front, lower, engine shroud, flywheel side. One wire goes to the key switch, the other goes under the flywheel to the SSI. The one to the key switch is the kill wire. You can leave them both unhooked but not touching each other. If it starts you will have to choke it to trun it off.
By unhooking the kill wire you are elimitating the tractor wiring from the engine. If you don't have spark then the SSI is bad.
