1 - 8 of 8 Posts
I have an SS 18 with an Onan engine. Engine # BG-MS/2980A and the carb is leaking gas from the low speed adjusting jet. Is there supposed to be an o-ring, or gasget to prevent this? Any help would be appreciated very much. Thanks, Litz
Cranky Motorsports
based on the repair manual, only the high speed or main jet (the one towards the front of the tractor or facing the carb the one on the right) has an o-ring. The low speed or idle circuit screw only has a spring on it. It should only be out about 1 turn give or take. Is it out too far?
The engine runs fine, and the jet is turned out a little over 1 turn. The engine is in an SS 18. Is it possible that the threads in the jet have worn to the point of leaking?
Cranky Motorsports
possibility... you could wrap it in teflon tape. I have done that in the past with good success.
Discussion Starter #8
The teflon tape seems to be working fine! I wrapped the threads on the jet a couple hours ago and so far it's dry! thx again, Litz
1 - 8 of 8 Posts
