1 - 12 of 12 Posts
Sprucing up the old Rotary Cutter
After my father passed, I salvaged an old Rotary Cutter that had been sitting behind the garage (unused) for about 18 years. A little rehab, some fresh paint and it is time to put it back to work.
Before
After
· I Love All Color Tractors
Are you sure that you didn't find the mower in the second pic as NOS from your dealer?
That looks great! Fantastic job. Did the inside of the gearbox look good too?
It was in great shape all I had to do was change the oil. Getting the old blades off was a different story!
I didn't think about the blades. I'll bet that they were a real bear.
You did a great job and it shows. :fing32:
Looks great. :thThumbsU When you put your blades back on put anti sieze on the bolts.
· USMC
Beautiful and use the anti seize on the blade bolts. slkpk
· 3K & Yet So Little to Say
That is amazing, you do great work.:congrats:
· 外人Geezer MTF Member
I only have two words - WOW!:fing32:
I do have a question for you regarding the paint. Looks great by the way.
Did you grind down, prime the spray?
Here's what I did with a few of my projects and things worked out great. Wire wheel or blast what ever is warranted. I roll on with a good roller rusty metal primer (old red-lead)and let it cure well, then I mix my own rustoleum to get the green and again get a good 1" by 4" roller and go to town. Nearly no brush or roller strokes and a very hard coating.
Discussion Starter · #11 ·
Yes lots of grinding, very thorough cleaning, primer, 3 coats of paint all spray. Nothing fancy Rustoleum works for me just need to let it setup well before final assembly.
1 - 12 of 12 Posts
