1 - 20 of 26 Posts
Proud Member of the 1K Club
yes in the line up those that have Homelite trimmers we carry replacement parts such as primer bulbs carb kits trimmer heads gaskets etc. we carry it we are also ordered our spring order of parts consisting of lawn boy gator blades which simply means if someone places a order for a lawn boy gator blade that blade ships out the same day the order is placed if it is before 1 pm est
Air filters for all kinds of machines
spark plugs galore
Kohler 4 cycle engine oil sae 30 hd
not to mention our hard to find homelite and poulan and sears craftsman parts thats right you save by shopping with us compared to Sears.com
so take advantage of savings thru us compared to sears
Run into problems we can help just a phone call away and it costs you not a cent to call us
Oregon Replacement Starter motors will be on sell Cheaper than anyone else on the net
so take advantage of shopping with us at CM Small Engines and save this Spring season
thank you
calvin
Calvin how much final price (incl. S&H) for a Gator blade for a Lawnboy Duraforce 10323 ? Just want the dollar amount...
Thanks
around 22.00 maybe lesser depending
on what the store shipping figures it out to be
2 stroke enthusiast
Buy in "bulk" Eddy, much cheaper! Thanks for the blades Calvin. Mounted one already to the 525 the other day, the M is next.
let me know how the M does with them
calvin
Discussion Starter · #8 ·
i was advised today by the us postal service that the rates are going up again in may i do not know how this will affect in the shipping rates lets hope it dont have a huge impact i wonder if it will be just first class mail going up or will it be priority and express as well
i will find this info out and let you all know what i find out
thanks
calvin
Discussion Starter · #9 ·
Briggs OEM oil filters on sell Now for $ 6.99 each plus $ 3.95 Freight
must use Paypal for this special offer price
only 12 currently available for this offer
contact me thru here for ordering
2 stroke enthusiast
Calvin, get you get me parts #'s for a spark plug and line replacement spool for a Poulan Featherlite trimmer? It's a straight shaft and I think 22cc or something close. Don't have it here in front of me to look at.
Discussion Starter · #11 ·
with you telling me a straight shaft featherlite i can think of one model of featherlite that is a Featherlite SST LE model
on the serial # at the end should be a dash then a single number 1 ,2 or 3 on this number
that number tells us repair folks what special parts that unit takes
if this is a SST le model then the trimmer head complete one is part # 952-711595
now just the replacement line spool itself part # 952-711596
your spark plug # RCJ6Y champion
but do me a favor double check the model of featherlite if it says SST LE anywhere on it then confirm the serial series number 1-3 that will be a good plus in knowing the above part #s fit the SST LE series
calvin
i feel bad i was not able to go to church today but i know God understands
2 stroke enthusiast
It is an SST model- I remember there was a double letter in there somehere, and you confirmed it. Not sure about the LE part though. I haven't used it over a year, so I basically forgot all this info. Thanks for your help!
Calvin,
Im going to be needing some tune up parts for a Kohler K181s. Nothing special, Air Filter, pre Filter, Spark Plug, Oil, anything else that is suggested for a out of hibernation tune up.
Thanks!
Edit: Looks like the carb will need to be gone thru, its leaking a bit of fuel just sitting there.
Discussion Starter · #14 ·
Calvin,
Thanks!
i have the kohler hd 30 wt oil in stock sells by the Quart
air filters and pre filters can be oregon replacement and spark plugs are Champion plugs
keep in mind that we sell blades too and belts and tires and tubes etc,
be looking for you to let me know you are ready to order now the carb issue will be oem parts cause i dont think oregon makes a replacement parts for the carburetors
but you have the tune up list down pat
calvin
Discussion Starter · #15 ·
i just know my poulans and weedeaters and homelites
which reminds me i have a couple Homelite SX 135 trimmers im going to be fixing up to sell so these will probily have a new carb on them or i will try best to rebuild the existing carb but the compression is still good on these trimmers so i will be working on these sometime in the next few weeks
and then i will place them on my store for re sale
it will be Calvin reconditioned Older Homelite trimmer non chinese made lol
Retired Super Moderator
Calvin I have a Weedeater GTH22 Hedge trimmer. I need the fuel line and a primer bulb. Can you help me with that?
Discussion Starter · #17 ·
jody that is a GHT22 and i do have them parts but i need to know what is the type number the serial # there should be a - symbol and a single digit number after it i need that single digit #
thanks
calvin
thanks
calvin
OK the serial# is 95244N and the other # is -2
Discussion Starter · #19 ·
ok that tells me your carb is a WT-379 walbro so the primer bulb is a 188-15 -1 but supercedes to 188-12-1 or you can simply find it 188-12
your fuel line is part # 530-069599
wow thats a old unit 1995 model at that
i have both parts on the store if you register a account you get 5% discount once the MTF member group has been activated and your sign in name on the store has been added to my MTF group discount area on my end of the store your 5% discount will be applied once that is set up
just let m,e know thanks
calvin
Thanks Calvin, just let me know how much for the general tune up stuff. Ive got to hit the road tonite, so itll be later in the week, maybe wed night night before I can get back online. You can send me a invoice thru paypal - [email protected]
1 - 20 of 26 Posts
