1 - 2 of 2 Posts
Anyone have any cheap ideas for splitting my BN? I don't have a cherry picker. I had it apart once to replace ring gear and I nust have done something wrong putting it back together. The clutch no longer works. Also I don't have access to the cherry picker any more, it was a pain trying to keep the front end straight anyway. Jim
You could take your front end off in pieces but you will still need some way of supporting the engine and clutch assembly. An engine crane from a surplus store usually sells for cheap. I'm pretty sure I got mine for under $100.00. Tricycle front ends are never easy to work with so I generally pull them off first so I can deal with the engine by itself. No use having it pivot around on 1 or 2 wheels like a ballerina.
-Leon
1 - 2 of 2 Posts
