I have a fuel leak at the inlet to the sediment bowl housing. The threads on the fuel bolt look ok but the female in the filter housing is stripped. I understand these types of AC/Delco parts are hard to find. Has anyone gone to spin on type of replacement. I have attached pictures.
Many if not most of those tractors didn't even have the glass bowl on there, went direct to the fuel pump from the tank, there are fuel filters on the other side before the injector pump. ;)
What I did on my tractor was to put a ball valve type shut off instead of the sediment bowl. I then put two inline fuel filters in the fuel line. The filters are very cheap $3.00 from checker. I don't know if this has adverse effects on fuel flowing to the carb, but the float should compensate for it.
