I am still trying to get this hooked up right....
I got the speed control cable hooked up as it should be to the vertical shaft. It now goes up and down as it should
HOWEVER, none of those cables attach to the carb? So how does the speed control effect the carb?? There is a shaft hooked up to the carb, but it connects to the doohicky lever at the bottom. The doohicky lever doesn't move, but this appears to be a fixed lever that the little springs are attached to.
Does anyone have a diagram that shows how this should be put together? I have the service manual but there isn't a diagram of this that I can find.
