SPECIAL --- 2020 Yanmar SA424-TL Hystat 4x4 Tractor Loader DEMO – Only 15 Hours - LOCATED IN ARIZONA
817 Views 0 Replies 1 Participant Last post by  TeamTractorEquipmentCorp
If you are looking for a barely used (DEMO w/15 hours), heavy-duty tractor loader, in excellent condition, for a value price --- then read on.
We are offering a well-equipped, heavy-duty, 2020 Yanmar SA424 4x4 tractor loader. Priced to sell quickly.
2020 Yanmar SA424 4x4 Tractor Loader
2488199
(You also get $2,500 in upgrades! See below!)
It is fully equipped:
  • Engine: Yanmar S773L Diesel (Only 15 Hours)
  • Horsepower: 25 BHP
  • Transmission: HST Power-Flow Cast Iron Transmission (Dual Pedals)
  • Front Axle: Cast Iron
  • Drive: 4x4
  • PTO: Touch Control Electro-Hydro Independent
  • Heavy Duty 3-point Hitch
  • Unitized Full Main-Frame Chassis
  • Premium Operators Station with Comfortable Seat
  • Dual Hydraulic Pumps
  • Heavy Duty Round Tube Steel Loader with Quick Coupler
  • Power Steering
  • Differential Lock Rear Axle
  • 10-year Warranty
You will also get $2,500 in SPECIAL UPGRADES including…
  • 5’ Heavy-Duty Box Blade with Cutting Edge
  • Bucket Forks – Clamp-Style Lifting Forks (for lifting like a forklift)
  • Rear Axle Ballast for Better Traction and Power
  • Upgraded Front Grill Guard (protects front hood)
  • FREE Drawbar Kit
2488200
Specifications:
  • Operating Weight (including ballast): 2,591 lbs.
  • 3-Point Hitch Lift Force at 24” Lift Point lb.: 1,189
  • Loader Lift Capacity: 1,281 lbs.
  • Independent Power Take Off: 18.1 HP (Shaft Size: 35 mm OD, 6 Splines, Full Open Center Hydraulic System: Primary Pump Capacity US gal/min. 4.3, Secondary Pump Capacity US gal/min. 3.7 (14.1)
  • System Pressure Psi: 2,429
  • Mid (PTO) Shaft Size SAE16/32, 15 Splines - Type Independent
  • Travel Speeds (Mph): Low Range: 0 - 6.3, High Range: 0-14.7
  • Fuel Tank: US gal (L) 6.1 (23.0)
  • Engine Oil: US qt. (L) 3.6 (3.4)
  • Engine Coolant: US qt. (L) 3.0 (2.8)
  • Transmission Oil: US gal (L) 4.1 (15.5)
  • Front Axle Oil: US gal (L) 3.7 (3.5)
  • Overall Length: 105.8 (2,688)
  • Overall Width: 54.1 (1,373)
  • Overall Height: 87.2”
PLUS --- you get a full 10-year warranty!
PLUS --- you can take advantage of either our SPECIAL FINANCE OFFER or BONUS CASH OFFER! You can apply here.
This 2020 Tractor Loader is all set and ready to go to work!
2488201
For more details on the 2020 Yanmar SA424-TL Hystat 4x4 Tractor Loader DEMO, please click here.
We can deliver it right to your door.
If interested, or to learn more, please call or text Ana at 480-410-3429 or call her at the office at 602-734-9944. You can also email her at [email protected].
Team Tractor Ranch - #1 Tractor Dealer in Arizona. We sell and service most major brands of tractors including Yanmar, Kubota, John Deere, TYM, Mahindra, Kioti, Case, New Holland, Massey Ferguson, Ford, Deutz, Case IH, Farmall, International Harvester, Branson Tractors, LS, Shibura, Claas Tractor, McCormick Tractors, Valtra, Solis, YTO, Montana, and Nortrac.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
