1 - 1 of 1 Posts
We are offering an immaculate, heavy-duty, 2019 Yanmar 324BXL-TL 4x4 Tractor Loader with a NEW 4’ Box Blade. Priced to sell quickly.
2490123
PLUS this tractor loader comes with options including:
  • HD Operator Canopy
  • Rear Auxiliary Hydraulics
  • Backhoe Ready Kit
(This tractor loader is as close to new as you can get without buying a new one, for THOUSANDS LESS!)
It is fully equipped:
  • Engine: Yanmar 3TNV80F Water Cooled Diesel (95.5 Hours)
  • Horsepower: 25 BHP
  • Great Yanmar Hydrostatic Transmission w/Dual Pedals
  • NEW 4’ Box Blade
  • On Demand 4x4 (Four Wheel Drive)
  • Heavy Duty High Reach Loader
  • Loader Lift Capacity: 1,283
  • One-touch On/Off Electro-hydraulic Independent Rear PTO
  • 3-point Hitch
  • Canopy
  • New Seat
  • Excellent Tires
100-hour Scheduled Break-in Service JUST COMPLETED!
2490124
Specifications:
  • Bore and Stroke in (mm) 315 x 330 in (80x84 mm)
  • Torque ft-lbs.: 457
  • Rated: 3,200 RPM
  • Torque: 45.8lb-ft
  • Battery: 640 CCA
  • Engine Coolant: 30 qt (28 L)
  • Engine Oil: 3.6 qt
  • Front Axle Oil: .92 gal
  • Fuel Tank: 6.1 gal
  • Transmission Oil: 4.1 gal
  • Wet Disc Brakes
  • Infinite Hydrostatic 2 Range
  • 3-point Hitch Category 1
  • 3-point Lift Capacity: 1,209 lbf
  • 4-way Loader Control Valve
  • Position Control Open Center Hydraulic System
  • Fully Hydraulic Power Steering
  • System Pressure: 2,429 psi
  • Ground Clearance: 98” (249 mm)
  • Minimum Turning Radius: 8 ft (26 m)
    Overall Height: 71.8" (1,824 mm)
  • Operating Weight: 3,606 lbs. (as equipped)
  • Width: 54” (1,373 mm)
The tractor loader is certified used and comes with an 8-year warranty!
We also offer financing. Learn more here.
This 2019 Yanmar Tractor Loader is all set and ready to go to work!
2490125
For more details on the 2019 Yanmar Tractor Loader, please click here.
We can deliver it right to your door.
If interested, or to learn more, please call or text Ana at 480-410-3429 or call her at the office at 602-734-9944. You can also email her at [email protected].
Team Tractor Ranch - #1 Tractor Dealer in Arizona. We sell and service most major brands of tractors including Yanmar, Kubota, John Deere, TYM, Mahindra, Kioti, Case, New Holland, Massey Ferguson, Ford, Deutz, Case IH, Farmall, International Harvester, Branson Tractors, LS, Shibura, Claas Tractor, McCormick Tractors, Valtra, Solis, YTO, Montana, and Nortrac.
1 - 1 of 1 Posts
