1 - 1 of 1 Posts
If you are looking for a pre-owned, tractor loader, for a value price --- then read on.
2494798
We are offering a heavy-duty, 2019 Kioti CK4010H-TL Tractor Loader with a 20’ trailer and 5’ rotary cutter. Priced to sell quickly.
(This tractor loader came from an estate sale.)
2495127
It is fully equipped:
  • Engine: Kioti Model 3FTH4U 40 Horsepower – 112 Cubic Inches - Diesel (665 Hours)
  • Transmission: 3 Range Automatic HYDROSTATIC Power-Flow with 2 Pedal Control
  • ASTM A27 Carbon All Steel Transmission and Front AxleHST Linked Pedal Kit
  • Loader WITH QUICK-COUPLER INCLUDED (ISO Skid-Steer Compatible)
  • Rear Axle Differential Traction Lock
  • Drive: Full Independent Four-Wheel Drive (4X4) (not just front-wheel assist)
  • Chassis: Unitized FULL STEEL Main-Frame Chassis (not aluminum)
  • 540 RPM Rear Power Take-Off (PTO)
  • PTO Cover
  • Heavy Duty 3 Pt. Hitch with 1,631 lb. Lift (compared to 1,389 lbs.)
  • Single Lever Joystick Loader Control
  • Upsized 27 X 8.5-15 Front Tires and 15-19.5 Rear Tires
  • Loader Lift Capacity: 1,835 lbs.
  • Auxiliary Dual 4-port Remote Hydraulics
  • Quad Port Rear Hydraulics
  • Heavy Duty Operator Roof Canopy
  • Backhoe Ready Hydraulic Kit
  • Dual Throttle Controls (Hand and Foot Link)
  • HD Grill Guard
  • Rubber Washable Deck Cover Floormat
Also comes with UPGRADED OPTION EQUIPMENT PACKAGE!
Package includes:
  • 20’ Trailer w/RAMPS
  • X-duty Colt 5’ Rotary Cutter (Installed and ready to work.)
THE TRACTOR LOADER WAS FULLY-SERVICED BY OUR FACTORY-TRAINED TECHS.
Major factor service included:
  • Engine
  • Transmission
  • Front Axle Fluids
  • Hydraulic System
  • Coolant System Power Flush
  • Upper and Lower Fuel System Service
  • Brake System and Linkage Adjustment
  • Valve Clearance Adjustment
  • Power Steering Service
  • PTO Dyno Tested (cycle and load)
  • Hydraulic System Flow and Pressure Test Calibration
This Tractor is excellent and ready to work hard.
Specifications:
  • Operating Weight (as equipped): 3,912 lbs.
  • Rated Revolution: 2,600 RPM
  • Travel Speeds: 0 – 14.9 mph
  • Battery 680 CCA
  • Alternator 2-55A
  • 4-way Loader Control Valve
  • 3-point Lift Capacity at 24” -- 1,631 lb.
  • Hydraulic Pump Capacity: 11.7 GPM
  • Hydrostatic Power Steering
  • Breakout Force: 3,464 lbs. (1,571 kg)
  • Maximum Lift Height: 98.4 in. (2,500 mm)
  • Clearance w/ Bucket Level: 93 in. (2,360 mm)
  • Maximum Dump Angle: 48°
  • Maximum Rollback Angle: 28°
  • Relief Valve Setting: 2,560 psi
  • Bucket Width: 66 in
  • Bucket Capacity: 10.10 cu. ft.
  • Bucket Rollback Force at Ground Line: 1,763.7 lbs. (800 kg)
  • Length in. (mm): 120.9 (3,070)
  • Overall Width in. (mm): 54.5 (1,385)
  • Overall Height (From Top of ROPS) in. (mm): 99.2 (2,520)
  • Wheelbase in. (mm): 65.7 (1,670)
  • Min. Ground Clearance in. (mm): 13.4 (340)
  • Turning Radius: 8’
BE REST ASSURED --- TRACTOR LOADER COMES WITH A 4-YEAR FACTORY WARRANTY!
This 2019 Kioti CK4010H-TL Tractor Loader
is ready to go to work.
2495128
For more details on the 2019 Kioti CK4010H-TL Tractor Loader, please click here.
We can deliver it right to your door.
If interested, or to learn more, please call or text Ana at 480-410-3429 or call her at the office at 602-734-9944. You can also email her at [email protected].
Team Tractor Ranch - #1 Tractor Dealer in Arizona. We sell and service most major brands of what tractors including Yanmar, Kubota, John Deere, TYM, Mahindra, Kioti, Case, New Holland, Massey Ferguson, Ford, Deutz, Case IH, Farmall, International Harvester, Branson Tractors, LS, Shibura, Claas Tractor, McCormick Tractors, Valtra, Solis, YTO, Montana, and Nortrac.
1 - 1 of 1 Posts
