1 - 1 of 1 Posts
If you are looking for a used tractor (trade-in with only 280 hours), in immaculate condition, for a value price --- then read on.
2503527
We are offering a 2010 Kubota L2800 Tractor and Landscape Rake. Priced to sell quickly.
Fully equipped:
  • Engine: Kubota D1403 Diesel (Good Compression – Starts and Runs Like a Top)
  • Transmission: Gear (Works Well, Plenty of Pull in the Gears In Both Forward and Reverse)
  • Four Wheel Drive (4x4)
  • 3-Point Hitch
  • PTO
  • Sun Shade Canopy
  • Front Weights
  • Seats (New)
  • Tires (New)
  • Brakes (Solid, Hold Well, No Slip in 10-degree Incline Test)
And no leaks in the tractor whatsoever!
Specifications:
  • Kubota D1403 30HP Diesel Engine
  • 3 cylinders
  • Liquid-cooled 85 ci [1.4 L]
  • Bore/Stroke: 3.15x3.638 inches,
  • Operating Weight: 3,200 lbs.
  • Emissions: Tier II
  • Rated RPM: 2800
  • Starter Volts: 12
  • 4X4
  • Transmission: 8 forward and 4 reverse speed transmission
  • 3 Point Hitch: Rear Type: I
  • Rear lift 1,985 lbs.
  • Cab - Two-post ROPS with Canopy
  • Chassis: 4x4 MFWD 4WD
  • Tires: 4WD Standard tires (ag): Front: 7-16. Rear: 11.2-24
And there are four great add-on options!
These include:
1).
Kubota Loader and Quick Connect 66’ Bucket with Joystick for $6,985;
2). Post Hole Digger with ONE auger bit 6”,9” or 12” for $1095
3). 4ft Box Blade for $995
4). 5ft Grader Blade for $725
Our Trained Service Techs have inspected, tested, and completed a full 250-hour factory recommended service with all fluids and filters.
Perfect size tractor at a great price!
This 2010 Kubota L2800 4x4 Tractor and Landscape Rake is all set and ready to go to work!
2503529
For more details on the 2010 Kubota L2800 4x4 Tractor and Landscape Rake, please click here.
We can deliver it right to your door.
If interested, or to learn more, please call or text Ana at 480-410-3429 or call her at the office at 602-734-9944. You can also email her at [email protected]
Tractor Ranch - #1 Tractor Dealer in Arizona. We sell and service most major brands of tractors including Yanmar, Kubota, John Deere, TYM, Mahindra, Kioti, Case, New Holland, Massey Ferguson, Ford, Deutz, Case IH, Farmall, International Harvester, Branson Tractors, LS, Shibura, Claas Tractor, McCormick Tractors, Valtra, Solis, YTO, Montana, and Nortrac.
1 - 1 of 1 Posts
