SPECIAL --- 2002 Case 570LXT Series 2 4x4 Skip Loader Landscaper with GANNON Box – 2320 Hours - LOCATED IN ARIZONA
1030 Views 0 Replies 1 Participant Last post by  TeamTractorEquipmentCorp
If you are looking for a used, heavy-duty skip loader landscaper, in good condition, for a value price --- then read on.
We are offering a well-equipped, heavy-duty, 2002 Case 570LXT skip loader landscaper. It was an arena property maintenance machine. Priced to sell quickly.
2485787
2002 Case 570LXT Skip Loader Landscaper
Starts and runs great!
(You also get thousands in savings when compared to buying brand new.)
It is fully equipped:
  • CASE 4-390 Diesel 4 Cylinder Engine (75HP – 2,320 Hours)
  • Shuttle Shift Transmission
  • 4x4
  • 82-inch Fully Hydraulic Gannon Box
  • 82" 1.03 cu yd Loader Bucket with Reversible Cutting Edge
  • 5,293 lb. Loader Lift Capacity
  • Brand New Seat
  • Brand New Tires
This is a good skip loader landscaper at a great price
2485789
Specifications:
  • Engine: 4-390 Diesel (75 HP)
  • Bore/Stroke: 4.02x4.72 inches
  • Rated RPM 2200
  • Torque: 197 lb-ft
  • Gannon Box Blade 82 Inches with 2X Reversible Replaceable Cutting Edges
  • 3-Point Hitch: Type II
  • Hydraulic System: 20.25 Gal
  • Disc Brakes
  • Steering: Hydrostatic Power
  • Operating Weight: 12,641 lbs.
  • Starter: 12 Volts
  • Oil Capacity: 11.6 Quarts
  • Fuel: 31.4 Gallons
  • Rear Hubs: 1.6 Quarts Each
  • Rear Diff: 15.1 Quarts
  • Rear Lift: 2,612 lbs.
  • Wheelbase: 84.5 Inches
  • Front Tires: 11Lx16
  • Rear Tires: 17.5L x 24
PLUS --- this skip loader landscaper was inspected and serviced by our factory technicians.
The skip loader just had its 2,000-hour factory recommended service. It has been fully FUNCTION TESTED with an Engine Compression Test, Cooling System Pressure Test, Hydraulic Pump Pressure and Relief Tests, Steering Cycle Test, and Charging System Test.
All tests passed or were adjusted within specifications. The Transmission and Torque Converter checked out great in both forward and reverse in all gears and speeds. The Loader Hydraulic Cylinders were recently REPACKED/RE-SEALED. The brakes are good and strong. PLUS the skip loader landscaper is equipped with a canopy.
2485790
This 2002 Case Skip Loader Landscaper is ready to go to work!
For more details on the 2002 Case Skip Loader Landscaper, please click here.
We can deliver it right to your door.
If interested, or to learn more, please call or text Ana at 480-410-3429 or call her at the office at 602-734-9944. You can also email her at [email protected].
Team Tractor and Equipment - #1 Tractor Dealer in Arizona. We sell and service most major brands of tractors including Yanmar, Kubota, John Deere, TYM, Mahindra, Kioti, Case, New Holland, Massey Ferguson, Ford, Deutz, Case IH, Farmall, International Harvester, Branson Tractors, LS, Shibura, Claas Tractor, McCormick Tractors, Valtra, Solis, YTO, Montana, and Nortrac.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
