Just to be clear, the one I use is not exactly a helicoil, which is kinda like asking for " Kleenex" which is a brand of tissue, not the product.
" Helicoil" is kinda like the same thing, there are several types.Most are a coil of wire that just goes down into the threads.
The one I used is more like a time-sert, which is a full threaded sleeve, complete with a flanged top to receive the spark plug compression washer . While not exactly ideal , they sure do work well, especially if you want an engine running, and cannot source a replacement head.
http://www.timesert.com/html/bigsert_sparkplug.html
M14x1.25
Standard p/n 5141
M14x1.25
Extended Version
p/n 5141E
.370
9.4mm
51401
n/a
.430
11mm
51403
51453
.600
15mm
51405
51455
.660
16.8mm
51407
51457
.905
23mm
51409
