I don't know the answer, but I look forward to someone posting it here. I have the 3012 and it is a heavy bugger. I think the deck alone will pass 100 #. Have you looked on SimpleTractors.com for the info?
Very good detective work :fing32:A '67 3012 weighs 735# dry...hydrolift adds 24#. A 48" mower deck weighs in at 135# (1969 listing shows 167#).
The closest I can find to a 3314 is a 3212H, wich would share the vickers hydro rearend, if yours has it. The 3212H with hydrolift shipped dry at 760#. I'm guessing gear and motor oil, and a tank of gas doesn't add all that much, so you're probably looking at a 800#+ tractor, given the 3400 series has more sheetmetal with the longer frame, hood and runningboards. No idea what the difference in the weight on the Briggs is between a 12 and 14hp.
Wow...I don't think I would ever have seen that in the manual! :thanku:Sounds like you have a model 3314V.
According to the manual linked below, your tractor alone weighs in at 883 lbs.
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=heCyEN8arH6rE3CG.5kbp796Dq
