1 - 7 of 7 Posts
Planning on putting some tail lights in your tractor? The shape of the 318 tail light housings are not extactly rectangular, it's more of a trapezoid with rounded corners. I put a set on a 320 I had back in the early 90s, and I made a cardborad template to make sure the light housings slid in OK, then I used the template to trace the outline onto the fender deck, and carefully made the cutouts.
The Missing Goonie
Planning on putting some tail lights in your tractor? The shape of the 318 tail light housings are not exactly rectangular, it's more of a trapezoid with rounded corners. I put a set on a 320 I had back in the early 90s, and I made a cardboard template to make sure the light housings slid in OK, then I used the template to trace the outline onto the fender deck, and carefully made the cutouts.
Yup. I like how the factory tail lights on the 420 and 318 looks so if they would fit, i'll get them for my 172.
IMHO, these cut-outs for the lites weaken the steel structure....and the lights don't take hits all that well(I have a 316).I would suggest an aftermarket tailite that would be cheaper and just use automotive goop to stick-em to the steel,if you don't want the lites just pull them off ,,,,put the saved cash into a cup holder ! or beer!:trink39: Jim
Super Duper Member
the rear lights on my 318 quit working 20 years ago...
Super Duper Member
I don't have the tractor close by. I might be going out there on Saturday. They're not actually broke. They aren't getting any power from the source.
1 - 7 of 7 Posts
