1 - 8 of 8 Posts
Hi,
I've got an old 165 hydro with the 38" single stage snow thrower. It has a lift spring (shock) which is bad (doesn't move at all). I found the part on the JD website, but they want about $85 for it. I'm sure somebody makes one that is significantly less expensive, but I'm not sure how to find one.
I thought someone here might have had the same problem. If so, please let me know what you did to replace the worn lift spring.
It is listed as:
Stabilus Lift-O-Mat
7222ZY 0655N 222/08 C 2
Thanks in advance!
Are you sure on the pn? For the 321 and 338 blowers I show the lift spring part number as M82761. Looks like $13 at greenfarmparts.com
I had to replace it and the bracket that attaches to the mower body last year (missing). Had to hunt around a bit for that bracket.
For the 38 there's a gas lift rod - might be the one you're talking about. Looks like about $67 most places.
Good luck.
This is the PN I am in need of:
AM102334
It is listed in the 1009 - 32, 32A, 321, 338 and 38-Inch Tractor-Mounted Snow Throwers - 30Aug01
section on JDPC as part number 6.
It lists for $85! Ouch!
yeah, that's the gas lift rod. $67 at greenfarmparts.com is the best I saw with a quick search
For what it's worth, I called Mark at Customgassprings.com and he can get one to me for about half that. Although I also hear that I shouldn't be able to move it by hand at all, so I am going to check to see if mine is even bad.
I couldn't move mine by hand and it turned out to be OK !
1 - 8 of 8 Posts
