My neighbor has an X7xx something, maybe an X738? It's either all wheel drive or 4 wheel drive, and a gas engine. I think he has the 54" blower. He stages it inside the garage and when it snows he just pulls out and goes down hill, turns around and comes back up. No chains and I think he might have wheel weights on it. He probably gains close to 100' in 500'. Paved drive. That thing does his drive effortlessly. My X540 works to get my drive, about the same grade, but only 75' or so. After seeing Tom's at work, if it was in my budjet, I'd be on an X7xx
I don't understand the infatuation with the 1025 on these forums, they are big, bulky, cumbersome and great at nothing. I would go with the X738/X739.
How straight or winding is the driveway? Are there winding sidewalks as well? Four wheel drive steers better if some of the snowblower weight is carried but it pushes the side of the blower into the cut. Four wheel steering might steer better as it brings the rear wheels around.
I have a lake cabin in Minnesota that I am trying to figure out snow removal for. The drive way is long, about 350ft and is gravel. Over the 350 ft, it rises about 20 ft, so there is a bit of a grade there. It is also a narrow driveway, so a blade is not an option, I need a snow blower. I talked to my local John Deere dealer and have narrowed my choices down to two, the X739 with four wheel drive and the X584 with four wheel steering. The X739 is about $8500 more expensive but I get four wheel drive. Do you think it is worth it? Any advise is welcome!
Personally I have open yard to mow and many other things that I need a bigger tractor for. If I'm going to spend 20+K on a tractor it better do everything I need it to.
I bought a Duetz/Allis 5220 26hp diesel 4x4 with a FEL and backhoe for my business used for a great price, but i was looking to upgrade from my JD 332 before I found the Duetz for just things I needed done around the house. Yep it's bigger than a 1025 but still small enough to get around things and do the jobs I need to do.
The 1025 is a nice "oversized" garden tractor with lots of options you can add. It is a better "homeowner" option than the X7xx stuff if you are doing more than blowing snow or mowing.
If all you do is mow and blow snow then that's great for you to only need/want an X7xx series, others need more than the X7xx series can provide. Thus the 1025 for them.
I don't understand why people still buy and use gear drive mowers. BUT that is their choice for them not mine.
To each their own it's not for us to judge.
The responses are personal due to needs and experience with these tractors. It is all advice to help the person asking what to buy to help them. Nothing more.
Instead of bashing those that suggested the 1025 maybe you should give a good reason for the X7XX stuff............
The obvious solution is to have both. Then you can use whichever one best fits the job.
Actually I've owned a x738 for over 5 years and a year ago stepped up to a 1025r. They BOTH have their place. Loved my x738 for lawn/yard work and clearing snow, awesome tractor for what it was capable of and was sorry to see it go. The 1025r isn't as nimble, maneuverable and a bit more tippy BUT it has a FEL, mower, backhoe and snow plow and runs circles around the x738 because of the capabilities and strength. It does for me what the x738 couldn't. With the 1025r it also takes little to no effort and mere minutes to switch from one work configuration to the next. Was the X738 better at what it could do, to a degree yes but not substantially. While I agree some 1025r owners like to push them both tractors have their place. Size wise, not much difference, capabilities are distinctive. I always recommend people think hard about the current and future needs then decide what fits those voids best. In this case I recommended a x738.
In case you never looked at a 1025r and x738 sitting side by side... don't know why people think the 1025r is a huge difference in size it really isn't. Bare 1025r tractor does weigh about 400 - 500 lbs more though.
These discussions regarding 1 series vs X7xx are frequent.
The common theme in them is people reinforcing their own purchasing decisions with the rationale being, "It must be better because I bought it". Often the author has no direct comparison due to not having owned both but that doesn't stop one from having opinions.
I have had a JD 2305, predecessor to the 1 series for 16 years and a X758 for 3 years.
My observations are:
1. Both are equally stable on hills and I have very steep hills.
2. It is delusional to think any 2 wheel drive is even close to being as capable as a 4WD. The JD 2305 is very capable with the snow blower, turf tires and no weights except the rim rear wheels as long as it is in 4WD. After I get down doing the driveway I often put back in 2WD to park and it will not back up a slight incline on pavement and it necessitates 4WD to put away.
3. The maneuverability of the JD2305 is not much different with the exception of the roll bar hitting tree branches as it doesn't fold.
4. The JD 2305 has a 2 speed transmission and pulls a heavily loaded 6x10' trailer on the hills easily, the X758 having only one speed and geared higher struggles.
5. The X758 mows much better. The JD 2305 with independent lift cannot be adjusted to mower higher than 2.75".
6. Many put loaders on the 1 series, personally I don't think it is a big enough machine.
7. I have 3 pt. attachments that when loaded would be pushing the capacity of the X758. (55 gallon sprayer and spreader).
View attachment 2578044 View attachment 2578045 View attachment 2578046
