1 - 1 of 1 Posts
We want to teach you the proper and safe way to use your tractor attachments to remove snow.
2482680
If you do not feel that you understand these steps and strategies, or can perform them safely, consult your tractor dealer or local mechanic.
Winter is here.
And that means snow needs to be removed. Or it will need to be removed soon.
This means you will need one of three types of tractor attachments.
Snow Blower
A snow blower is a popular option.
2482681
Many snow blowers use an auger to chop snow and feed it into an impeller. Then the snow is expelled through the chute.
One thing to remember is that snow needs to be blown before it gets too heavy. Therefore, do not let much snow accumulate.
If the snow is too heavy, it places a great deal of strain on the blower attachment.
Keep in mind that if you have a front-mounted blower, you must make sure to remove buckets and loaders.
Plow Blade
Moving snow with a blade is easy, effective, and straightforward.
2482682
A plow blade will allow you to clear snow closer to the ground than you can with a snow blower.
Blades come in a slew of styles, sizes, and various mounting options. You can get a rear mount, sub-frame, or front-mounted blade.
Plow blades are also used for other work tasks throughout the year.
Snow Pusher
A snow pusher is simply a large box that pushes snow.
2482683
Pushers are great attachments because they can move a large amount of snow at one time --- far more snow than a plow blade.
They also do not leave “wind rows” like plow blades.
Pushers are great for open areas, big areas, and empty lots.
There are also pull back blades in these pushers that can help remove snow close to garage doors. Pushers are only built for front-mounting, so you lose some of the flexibility of other blades.
All three attachments are effective.
If you need any further help, or have any questions about snow removal, tractors, or anything else, please contact your dealer, local mechanic, or call us at 602-734-9944. Please ask about our current new and used tractor supply.
Team Tractor and Equipment - #1 Tractor Dealer in Arizona. We sell and service most major brands of tractors including Yanmar, Kubota, John Deere, TYM, Mahindra, Kioti, Case, New Holland, Massey Ferguson, Ford, Deutz, Case IH, Farmall, International Harvester, Branson Tractors, LS, Shibura, Claas Tractor, McCormick Tractors, Valtra, Solis, YTO, Montana, and Nortrac.
1 - 1 of 1 Posts
