snow plow for my LT4000
6706 Views 13 Replies 6 Participants Last post by  guinelle1
i have an older LT4000, it has an 18hp on it. found this deal on craigslist. plow with chains and weights. just wondering will it fit? i thought most of the plows fit on almost all the models?
link to ad
http://chicago.craigslist.org/wcl/grd/1306255536.html
1 - 14 of 14 Posts
I have no idea. I would buy that in a heart beat if it was closer to me.
yea, someone already called the guy, if he doesnt call back tomorrow to go look at it. i will be able to go get it. i pray that i get the plow!
That looks just like the one I had on my '94 LT4000.
yea, i just hope the other guy doesnt call on it =) good deal.
That plow won't fit my 1980's LT4000. I need the longer channel iron,about 3 ft. long to go under the mower deck.
The one shown, is for a more 'modern' unit, where the raise/lower is not controlled by the mower deck r/l lift mechanism.
FYI.
i got the plow, quite a ride out there to go get it. since it was off a newer mower mount will require a bit of modding. nothing to serious. will post pics once i get it finished :thThumbsU
FYI.
mine isnt that old. the bolt holes are close. the front bracket is also ment for a lower frame. i will put a piece of steel to extend it up to my frame.
Good buy I'd say. Glad you got it. Wish it was me though :p
yes, plus weights and chains.. ill be ready this winter!!:bannana:
it will fit all plows are mostly compatible great deal to
great find! i just got a 42 inch old style like what you wanted for my lt for $50 wanna trade haha
a little cutting here, a weld there, a small bracket over there. all you need is some of that white stuff to try her out.
Actually no, i had to cut off 2 brackets that extended back over the axle. they would of hit the axle preventing it from swaying, i could of put a knotch to go over the axle but the hole wouldnt line up. the best bet was just to remove it. the knotch probably would of been so big it wouldnt hold it that much anyway. got some pics
With the rear mount cut off
Where the mount would go if it was on
1 - 14 of 14 Posts
