So my driveway is paved as of this past summer. Was gravel/limestone-crush before that.
I will be using the FEL once again as a plow this winter, but I want to avoid scratching the pavement with the steel edges on the FEL.
To that end, I'm thinking about adding a plastic or rubber edge to the cutting edge of the FEL, and a couple of blocks to the under side, along the lines of "skid shoes" to allow it to glide on the pavement in float-mode.
Questions:
1. has anyone done that sort of mod to their FEL?
2. if so, can you please post some pics?
3. how well did it work out in the end?.. did the snow get scraped by the plastic or rubber cutting edge effectively?
4. should I use rubber?... nylon?... polyethylene?... or what?
5. does the plastic or rubber wear out too quickly, causing a rounding of the edge, diminishing the scraping effectiveness?
thanks in advance!
Questions:
thanks in advance!
