The universal plows likely will require some fabrication of mounts on your part, to attach it to your zero turn, as the frame of a zero turn isn't that similar to a lawn tractor or an atv, and then your ZT has even more limited space for mounting it, as I believe the mechanism for the steering system is located between the frame rails just behind the front wheels, so that also limits where/how it can be attached.
I would say it's unlikely you'll find a 3rd party bolt up plow setup, unless your S48 happens to have very similar mounting points up front for it that other tractors have (so it can be sold for a bunch of models without needing a different mounting system for each one).
I would suggest going with Cub's setup unless you feel comfortable with designing/fabricating parts yourself..
Pushing snow straight ahead will work totally fine, it's angled plowing that may be a problem, as when there is much snow, it just gets too much for the relatively light ZT.
This sounds completely backwards to me. If a truck attacks a pile of snow with a blade that is square to the front of the truck, the truck will often stop dead in it's tracks. If that same truck hits that pile with his blade angled, he has a chance of pushing through it. This is the whole reason why the V blade was invented. When pushing with the blade straight across the front of a vehicle, and making a long push of snow, the snow will eventually build up in front of the vehicle, and stop it. With the blade angled to the side, it diverts to snow to the side, and out of the way. Diverting force to the side is always easier than tackling it straight on.
Jeff I'm guessing that Dave thinks that because the ZTR has front tires that swivel it makes it more likely to push when the blade is angled. however, it is the drive tires and the sticks that the operator uses to keep the z going straight while plowing with the blade angled.
.There are so many YouTube videos of ZTRs plowing snow like a boss.
I don't doubt you that there are videos of people using ZTRs to push snow, and effectively. And maybe I just don't understand the physics of a ZTR (I've never owned one, so it's very likely). For most vehicles, pushing snow with an angled blade is easier and more productive than with the blade straight, maybe a ZTR is one of the exceptions to the rule.
Well, the steering front wheels (instead of casters) may help, that Cub is a lot lighter and a much different weight setup than a Grasshopper (and a pickup truck with a V plow is in a different time zone). Having independent hydro's help with angled plowing, but the outside wheel (away from where the snow being plowed to) needs to have really good traction all the time for it to not get pushed sideways, whereas pushing the snow straight ahead is much more tolerant of individual wheels losing traction.
If the o.p. clears the snow all the time before it gets driven over, so there isn't packed snow/ice, then it should work fine, but I expect he'll notice it sliding if snow/ice does build up and he gets a big dump of snow. It generally won't mean he has to turn around, park it in the garage and get out the walkbehind snowblower, but it will be something he will have to adjust for.
yep it's the hydro gear ZT 2800. I'm not too worried after seeing what it could do in the snow yesterday. Granted, no blade on it, but still had the deck on (now, don't yell at me for that, I was just testing and it was all the way up!)
Thanks guys
