1 - 2 of 2 Posts
2 stroke addict
Posted in the Walkbehind section, but I will put it in here too.
I had a BBC Toro Suzki 4 cycle with a bad deck, throwing it on a Snapper deck.
Not done yet, still have to convert the Snapper to SP, and figure out how to disable the BBC.
Pics of it so far:
I plan on also doing a 2 stroke version if I can find another Snapper mower and a engine. :trink39:
Well I changed the design a bit, but I am making a new blade adapter that gets rid of the BBC flywheel, and all the other BBC pieces.
it is 3" square, by 1 1/2" thick. it will have a hole in the middle to slide over the crank, and it will have a taper to match the one on the crank. local sheet metal shop is cutting the steel for the adapter right now. I will get pics as soon as the adapter is done.
It will also have 2 threaded holes for the blade bolts.
Started work on the blade adapter.
Can't see pics
1 - 2 of 2 Posts
