I have replaced the battery, clutch switch, and start switch. I have verified the clutch has resistance and that the switches on the oil, seat, joy stick, and brake are functioning properly. The fuses are not blown. The solenoid is working.
The engine cranks only with the clutch switch ON. With the clutch switch OFF, it is dead other than the warning beep.
I suspect something (a bare wire perhaps?) is acting as a kill switch but I'm open to other suggestions. I've run out of things to replace or test.
Thank you.
