Apparently I am not the only one with this issue. The thing is, nobody every produces a solution. The threads just die.
www.lawnsite.com
Also note that this unit (FH641V-ES25) has both an alternator AND magnetos. There are two coils with pick-ups outside the flywheel. These serve only to power the plugs. INSIDE the flywheel there is a rung of what appear to be wound copper coils, all the way around. This goes to the stator. Again, output from stator is 30v DC, which manual shows is correct.
Kawasaki 21HP Not Charging
Recently purchased Ferris, with a FH641v not charging. I didn't know it wasn't charging until it wouldn't start, about 3 PTO hours later. I'm new to these Kawasakis, and don't have many hours working on anything without an alternator. I put a meter on the output side of the voltage regulator...
