1 - 10 of 10 Posts
It would be the furthest back lever to the right of the seat on the fenderpan.
On the inside of your left knee should be the speed limiter lever, make sure that is moved UP as high as possible.
With a good hydro, the speed in low range reverse should be roughly walking speed, high range should be holy crap hold on speed.
HI-LO is the middle lever. The one for the rear PTO as at the back of the fender.
As Cat385B mentioned, the speed limiter is often the culprit. If it isn't in position 4, at the top of it's movement, the tractor is going to be noticeably slower, especially in reverse.
I will check it out.I thought the back lever was for pto I moved it long ago didn't feel like it was hooked to anything. same with inside left lever.
Discussion Starter #8
checked rear lever.had no resistance. checked linkage under seat,the arm was broken.broke out the welder in short time I had speed in forward and reverse!! thanks for the help!
1 - 10 of 10 Posts
