1 - 7 of 7 Posts
Retired Mod
i have to look at a tractor tomorrow. its a briggs 17.5 OHV
model 31c-707
type 015-4e1
code 040-3132d
this tractor is blowing large amounts of white smoke after running for a few minutes. the tractor was diagnosed with a bad head gasket (not by me) so it was changed and after about an hour it started smoking again. i'm thinking it could be a bad float/needle valve as the woman says the oil isnt overfull but does smell like gas. has anyone here ever dealt with this issue on this motor?
Retired Mod
I just got back from there. its the needle valve not seating & its filling the breather tube with gas when it sits. now i just have to figure out what carb it has as its showing 2 different ones! :banghead3
Senior MTF Poster
Shouldn't be too hard, look at the fuel inlet. Best insurance is to install a fuel line shut off valve and use it when the engine is not running.
Walt Conner
Retired Mod
Walt Conner
Thank you Walt. after taking a look at the diagram again i noticed that the floatbowl on one of them was held on by two screws on the sides so it was easier than i thought. i advised the customer on the shut off but for now they just want to replace the needle valve.
Senior MTF Poster
Yeah, you are right, the NIKKI carb does have two screws holding the bowl.
"i advised the customer on the shut off but for now they just want to replace the needle valve. "
Bad choice, dozens of these engines are reported ruined here just from this cause and I get lots of them in too.
Walt Conner
1 - 7 of 7 Posts
