1 - 14 of 14 Posts
I seem to be having a hard time finding smaller 3pt sprayers. all I really need is a 15-20 gallon.
anybody know a company that makes them that way for a cat 1 3pt??
thanks
USMC
You could build or buy a carry all and set the sprayer on it. Never seen one that small for a 3PH sprayer. Another thought would be too buy the 3 PH frame from Fimco and then add your sprayer to it. slkpk
9K+ Poster
:ditto: Some members here have modified small tow-behind sprayers to fit their 3PH. :)
Google AG Spray Equipment. They have a 25 gal. 3pt model. Sorry i don't know how to post a link.
USMC
Any reason you don't use your 3PH 45 gallon sprayer and only use 15-20 gallons of product? slkpk
Likes Vintage JDs
I know this company makes these specifically for the Kubota BX series, but you might contact them to see if it would fit your tractor:
http://bxpanded.com/index.php?l=product_detail&p=11
That's a great suggestion! I will post a link to a slightly different model that Bxpanded also offers, for 3PH mount, in two sizes (16 or 26 gallon):
16 or 26 Gallon 3PH Sprayer by Bxpanded
They indicate that this product fits most tractors with a Cat 1 3PH, so not a Kubota exclusive by any means.
Or if you are set on a smaller tank size, why not just change out the tank to a smaller one. Will still be cheaper than a new sprayer.
I am making a 3pt sprayer for my tractor. I am going to use a 25-30 gal tank for now, but if I need to I can upgrade to a larger tank.
Since you have a 45 gal tank, why not as suggested before, just fill up what you need?
Discussion Starter · #10 ·
thats what i do now, just mix up small ammounts, but the physical size of the unit is quite large.......
If your looking for a small spot sprayer, then you might have to make something up, or buy a regular sprayer and make up your own mounts or place it on a carry all. I have never seen anything smaller than a 25 gal sprayer for 3pt mounting. If you werent so far away, I would say give me your 45 gal sprayer and I would make you a 15 gal sprayer :)
1 - 14 of 14 Posts
