why not just use the original regulator/rectifier? the only reason it would not work in place of the 2 diodes would be if the supply voltage is not high enough.
I am trying to help another member, I think the Orginal alternator is a "single" wire, and the new engine has the "dual wire" These two alternators are wired different. The Dual is Center taped, alowing for two 14V outputs, One of which is rectifed. The Single wire outputs 24V which is fed into a Regulater (bridge) to output 12VDC at higher amperage.why not just use the original regulator/rectifier? the only reason it would not work in place of the 2 diodes would be if the supply voltage is not high enough.
