I am purchasing a piece of commercial equipment spec'd out to mow a 30 degree slope ***. It has a B&S Vanguard 993 cc, 37 HP V-Twin engine. I am curious why the literature cautions a maximum continuous mow time of 10 minutes mowing a 30 degree slope? The time increases to 20 minutes on a 20 degree slope.
My first thought for this caution is something oil related. But it has an oil pump, oil cooler and the sump is centrally located. Any thoughts? related engine specs are:
- Oil cooler reduces oil temperature, improves lubrication and extends oil change intervals
- Dura-Bore cast iron cylinder sleeve assures long engine life and oil control
- Convenient oil drain locations for trouble-free maintenance
- Full-pressure lubrication with spin-on oil filter cleans oil and protects engine components to ensure maximum lubrication and long life
- Centrally located oil pump and pick up for faster priming allows for a higher angle of operation
- Pressure-regulated full flow oil filtration keeps oil clean longer, extends time between oil changes and improves bearing life
- Oil dipstick provides easy access to check oil levels
