1 - 3 of 3 Posts
The hitch itself will but you will still need the right lift bar for it. The other parts are really only for the fender deck 110 & 112 and the 200 thru 216. But the hitch part of it is the same from the 140 thru the 317. But you will need the integral hitch lift bar there is a example in this link for the 120/140 http://www.weekendfreedommachines.com/advertisers/buske.html that bar in the link should work on your 312 :thThumbsU
If your good with metal the actual plans are out there for the hitch and the lift rod. I can send them to you if your interested. I had the rod fabricated for my 314 by a friend.
1 - 3 of 3 Posts
