I just bought a 314 hydro and was wondering if I could take the sleeve hitch off my JD210 and install this on the the 314.The hitch hooked to the manual lever on the 210.What would I need to install onto the hydro if this is possible.
If it's the same integral hitch I have for my 316 Kohler it should have a mounting bracket welded on at the right spot on the right side. I see the lift arms occasionally on Ebay for about $10-20.
· Super Moderator
The hitch itself will work from the 210 But as you found out you will need this Hitch bar here a picture of it under the 120/140 http://www.weekendfreedommachines.com/advertisers/buske.html you should not have to modifie the hitch itself. IT should be two diffrent connection point's on that hitch. :thThumbsU
