Sleeve hitch Modification--can I do this.
3283 Views 6 Replies 4 Participants Last post by  SonnyT
Here is a pic of my setup. The hitch is controlled by the same lever that controls the grass cutting deck.
I want to separate the two by adding a lever on the rear to control the hitch only. I can probably figure it out but you ideas and opinions will be appreciated and probably make it simpler.
There aare times when I don't want to remove the deck in order to use the sleeve hitch.
Marvin
1 - 7 of 7 Posts
they made some like that- it had a plate that bolted to the back of the tractor, and had a lift arm with a link that goes to the hitch.
go here and type in PN 486.24535
that will give you a manual for what it looks like.
Text Diagram Line Design Parallel
Thanks, it looks like I can convert what I have by using your diagram. I would have to put in three sets of holes in #7 where it attaches to #8 so that I control the lift height and also change the force I would have to apply to the handle based on the weight (Implement, boom or whatever) I had on the sleeve.
Thanks again, Marvin
Here is a picture of the one I made, have since converted it to a electric actuator, but the manual one worked fine. Also check the forum link when I was building it, several guys posted some good ideas in the Thread, especially about the lever!
http://www.mytractorforum.com/showthread.php?t=75334
Thanks SonnyT. That helps a lot. QUESTION-----does the bend in the lift rod (rebar) allow it to cantilever over the fulcrum point and stay in the raised position? Kinda like chain binders do.
Marvin
Yes :thThumbsU
Marvin
Yes, that is what kept it from falling back down. trial and error on the angle. Only took a couple of tries to get it right. :fing32:
1 - 7 of 7 Posts
