I have a 1992 Simplicity GTH 20 . The rear PTO bearing was making a noise so upon dissasembly i noticed a piece of the transmission where the the bolts go through the rear PTO carrier bracket and into the transmission a piece on the trans just fell right off. My question is - Is there pressure in the rear Transmission? I don't want to spend alot of money on this so can i just fill the hole with RTV gasket maker type material or should i use JB Weld to fill the hole? i just want to keep the fluid from coming out for now.
e
