I've got an 18 hp Briggs & Stratton vertical shaft in a late model Landlord DLX. The shaft size is 1 inch x 3-5/32 and has a 16 amp alternator.
I don't know that I want to rebuild this engine or buy a new one for this tractor and am looking around for a used engine.
What I"m finding is that there are a TON of tractors out there with the same size shaft, both single and twin cylinders - but, the alternators are 5/3 amp, 9 and 16 amp - the 16 amp being the hardest to locate.
Question is - what is a 5/3 amp alternator and how does it differ from a 9 or 16 amp alternator? When is the 5/3, 9 and 16 amp alternator applicable? This tractor has an electric PTO, don't know how much this load is. The tractor has lights too and maybe when PTO and lights are going, 16 amp is necessary?
Another thing to consider is the exhaust outlet. The present Vanguard exits out the front and down to a muffler below/in front of the frame.
For this tractor (right now) I don't want to spend a pile of $$$'s, just get it going and mowing. I think a 14 hp engine would suffice as a minimum hp.
Any advice on the above? Any ideas for a replacement motor, like from another brand tractor? I've been on the lookout for a Broadmoore with a bad tranny as I believe some of them used a 16 hp twin vanguard engine that might fit my needs.
Thanks!
Bill
Thanks!
Bill
