1 - 1 of 1 Posts
in the process of rebuilding and found that on the right side wheel hub there is a bolt with spacer shown in the picture and on the left side there is no bolt and spacer. The bolt was tight, i have it loose as it was apart for cleaning. should there be a bolt and spacer on both sides, or is there a reason why there is only one on the right side?
thank you
David
1 - 1 of 1 Posts
