. As far as the on and off, check your wiring and switch. As for the belt check the clutch for a lot of excessive play.
. As far as the on and off, check your wiring and switch. As for the belt check the clutch for a lot of excessive play.The PTO keeps turning off and on when I try to mow. It also ate the belt. Is this going to be a PTO replacement, or am I missing something? Thanks in advance.
Hi Dwarven1 .... View attachment 2503785 Have you checked the air gap on the PTO?..which model of Broadmoor is it?
