1 - 3 of 3 Posts
I just baught a very used landloard. Any info ? It has the following #'s serial# 001587, Ellectric start # 990350, Hydro ele start, # 990351 , manuar start 990352, Help. It has a broken axle tube. I removed the axle shaft , its good , How do i remove the axle tube> Any HELP THANKS> Blane
the numbers you show are the MFG#s for the 1966 Landlord 101 :eek:mg: very hard to find machine i own one myselfe and the rear right axle shft did the same thing after fixing add a muffler clamp or 2 on each end of the shaft should help from happening agine any pics? and what implaments do you have for it and witch are you looking for? simplicitysam101 sam in new york
1 - 3 of 3 Posts
